Vizio m50-c1 has no picture but has both sound and backlights.
Vizio has no picture at all. Vizio logo does not light up when turning on tv. Unable to see menu screen with flashlight test. Have replaced both the Tcon and main board but no change. Still no video at all. Any ideas? Thank you
Bu iyi bir soru mu?
7 Yorum
You said that the Vizio has backlights, but you still went for the flashlight test, so I’m a little confused. Normally, you’d do the flashlight test when the unit doesn’t have backlights. So the unit powers on, the display brightens and you can hear audio, but you receive no images on the display - correct?
TechWizard tarafından
yes tv has backlights. yes tv powers on display brightens but no images at all. no vizio logo or anything on screen. thank you
Tony Fulbright tarafından
I'd make sure that the LVDS cable(s) is seated well in the main board as well as the TCON board. It's possible this cable(s) could be bad as well, so it might be worth buying a replacement.
Do you have recommendation of where to get a good LVDS cable. ShopJimmy doesn't seem to sell them with the TCON or Main board.
thejaylife tarafından
I have the same issue "Vizio m50-c1 has no picture but has both sound and backlights". So far I have changed the power board and the T-con board and still the same. I was wondering what the solution ended up being. So it appears if I disconnect one of the cables to the screen on the T-con board I have half of a display so I guess my screen buffer is shot which is built into the display
Michael Aldon tarafından
2 tane daha yorum göster
