Ana içeriğe geç
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
46 Soru Tümünü görüntüle
Apple Logo shows for 5 seconds then shuts off after digitizer change
I changed the display, home button, and rear camera on an iPad 5 and now when I turn it on, the Apple logo comes on for 5 seconds then goes away and only the backlight stays on.
I have taken the device back apart several times to make sure that all the connections are clean and properly plugged in, but it still acts like this.
What am I missing or where do I go from here?
Everything worked good on it when it was brought to me, minus the digitizer being broken..
Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
What happens when you use the original digitizer?
tarafından
That is not an option since the original is in about 1,000 pieces.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
I suspect you have received a faulty or low quality digitizer. I would try another digitizer just to be 110% sure. If a new digitizer doesn’t fix anything; I suspect it’s a Logic Board issue.
iPad 5 Screen Digitizer
iPad 5 LTE Front Panel Assembly Replacement
iPad 5 Screen Digitizer Görseli
Ürün
$44.99
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I will throw a different digitizer on tonight when I get off work.
Thank you.
tarafından
Yorum Ekle
Yanıtını ekle
sunruh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 76
