Ana içeriğe geç
The Canon EOS Rebel T5 is an 18MP DSLR camera released in February 2014. Also known as the EOS 1200D and the EOS Kiss X70.
20 Soru Tümünü görüntüle
Flashing Yellow light in front of camera
Yellow light flashing on front of camera and will not let me take a picture. Pop-up flash kept hitting hat brim and eventually stopped working. This is for my EOS Rebel T5 1200D
I have removed the battery and that did not solve the problem.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I know that you probably aen’’t having this problem anymore but I also had it and figured out that I had accidentally turned on the timer on my Rebel t6. The yellow light should blink for about ten seconds before taking a picture. To turn this off (on the t6) click on the left button next to the set button and then select “single shooting”. I hope that helps!
Bu yanıt yardımcı oldu mu?
Puan 5
5 Yorum:
Thank you so much !! It helped me
tarafından
It helped me too, thanks buddy
tarafından
Thank you! That totally fixed it. God bless you!
tarafından
Posted photos on my answer to confirm this, checked on a T6i.
Essentially the T6i is the full fat version of your T6.
tarafından
I made an account so fast and even screwed up my name just to say thank you for this. I've been photographing all my life and a rookie mistake almost sent me into a spiral because I'm in a rush
tarafından
Yorum Ekle
What does it do when you try to take a picture? Specifically, at what point does it stop? Does the lens autofocus (if you have an autofocus lens for it)? Do any of the viewfinder lights come on? And what shooting mode are you in?
The flash thing is weird. It shouldn’t have stopped working just from hitting the brim of your hat. Have you tried turning flash off and making sure it’s not set to auto flash?
Puan 0
Yorum Ekle
It's the self timer mode.
Puan 0
Yorum Ekle
Yanıtını ekle
Neil Fox sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 7,773
