Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Soru Tümünü görüntüle
How much does it cost to have the screen replaced?
I was wondering what Apple charged for replacing the display for a 15” mid-2014 Macbook Pro? It is out of warranty and very badly scratched!
Thanks,
Update (11/22/2018)
I’ve added a photo, which actually makes it look worse than it is for everyday use. For the most part, I forget the scratches are there whilst I’m using my MacBook, but every now and again it annoys me.
As to how it happened? I’m not entirely sure! I think it' has been over time due to poor cleaning attempt and potentially my cat!!
I'm not comfortable that I could follow those instructions successfully myself. It’d be great to find a private repairer instead of Apple. I am in Australia.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
6 Yorum
Lets see if @pollytintop can help you. She's located In Batemans Bay, south of Sydney.
tarafından
Thanks! I should've said, I am in Brisbane too.
tarafından
$500 for just the screen... not cheap. Maybe look at a screen protector that may smooth out the appearance a bit? Am not local to Brissy so no recommendations, good luck.
tarafından
@pollytintop Maybe try a glazed surface screen protector, if it can be found..I tried the glass kind used in iPads but it doesn't make much difference.
tarafından
I'm not sure if this helps Apple did offer an extended warranty on damaged anti-reflective coating failure which is really your issue here. Apple Extends Free Repairs of Anti-Reflective Coating on Select MacBook and MacBook Pro Models. Its worth the trip to the Apple Store or authorized service center to see if you can convince them you didn't know of the program as you were in the outback ;-}
tarafından
1 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I can’t answer what Apple charges ;-} But I can tell you, you can do it cheaper!
Here’s the IFIXIT guide MacBook Pro 15" Retina Display Mid 2014 Display Assembly Replacement and here’s the needed part MacBook Pro 15" Retina Complete Display, Late 2013 / Mid 2014
But are you sure you need a new display? How about telling us a bit more on what happened and if you need to post a pic or two so we can see the damage Adding images to an existing question
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
MacBook Pro 15" Retina Display Mid 2014 Display Assembly Görseli
Kılavuz
Zorluk:
Orta
30 minutes - 1 hour
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
If the screen is not actually broken and it has no sever dents, I would try for a “Flat Rate Depot” repair directly from Apple. @pollytintop, @jayeff or @benjamen50 may know the phone number for Apple direct in Aussyland. Apple will fix any and all problems for that flat rate fee. In Texas the cost is $357 USD with shipping and tax included $494.45 AUD.
I doubt you can even find the part for that price.
In the USA you call them described the problem, ask for a flat rate repair and they have a FedEx overnight shipping box on your doorstep the next morning. Total time including the day you called is four days. Be sure to back up your data before sending in just in case.
Puan 3
3 Yorum:
you are right about the cost there @mayer .. the cost for the screen alone here is $500aud.
tarafından
I like how outdated the image is of that Apple Store. Anyone else notice that the iPhone shown in the right hand side of the store is an iPhone 3G? I also see a cheesegrater Mac Pro near the back left of the store too!
tarafından
Yorum Ekle
Hello, it looks like anti glare filter delimitation plus scratches. Google for info. Some people used rubbing alcohol, Listerine, etc. to remove the anti glare filter. This will not fix the problem with scratches. Well, you can get an external monitor.
Puan 0
Yorum Ekle
Yanıtını ekle
Ross Hopkins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 12,492
