Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Soru Tümünü görüntüle
Audio port not working after repair
I replace the digitizer and battery on one of these and it worked well. Customer reports that the audio port no longer works. Since I didn’t work on or remove that portion of the phone, what could I have done to cause this? @refectio
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Did you disconnect the Lightning Port connector by any chance? It is surrounded by small components, some of which directly communicate with the headphone jack. If you accidentally pried some off, this would cause your issue.
Otherwise, there’s not much you can do to impact the headphone when changing just the screen and battery…unless a tool went astray during the repair. If you have a jewellers loupe, do a thorough inspection of the area around the battery and Lightning port connector.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
mayer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 45
