Ana içeriğe geç
Apple'ın, isteğe bağlı hücresel bağlantı özelliği de bulunan üçüncü nesil akıllı saati; 22 Eylül 2017'de piyasaya sürüldü.
Water damaged Apple Watch
I went out for a run, took my watch off because it died and I put it in my pants pocket. I washed those pants and now the screen is cracked and has water damage. It will not turn on. I’ve tried everything. Is there any possibility that my watch could be fixed and if so what would it cost? It’s a Series 3 I believe.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
3 Yorum
My Apple Watch died while I was inside the Pool and now is full of water inside how would I fix this ?
tarafından
Hi my Apple Watch died too but I washed my hands my screen was already cracked and it stopped there got soap and water on the display and if I’m super unlucky it will be in the battery or logic board too I want to repair it by myself but idk what is broken or what to do someone I need advise and some thoughts if it’s riviveable
tarafından
Same thing happen to my Apple Watch. Did you have to replace everything or just a few different parts?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you believe it has water damage, you must disassemble and clean it using at least 91% isopropyl alcohol, (you can use this Apple Watch Series 3 Teardown to do that) make sure to scrub everything with a toothbrush.
more details on water damage can be found here: Electronics Water Damage
It is a tough repair, but as long as you follow the instructions you should be fine.
Bu yanıt yardımcı oldu mu?
Puan 9
1 Yorum:
I went to the beach and I didn’t lock my Apple Watch and now the brightness is red and I can barely see or know where things are, hoe can I fix it?
tarafından
Yorum Ekle
I was scuba diving and found a Apple Watch and I want to see if it can be fixed
Puan 0
Yorum Ekle
Yanıtını ekle
Breniecia Camphor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 42
Her zaman: 38,111
