I Can t charge my device
My device is amazfit pace 2 and i cant charge it
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 454
Please elaborate your issue, why you are unable to charge it. Do you have the charger for this device.
JAI GANESH NAIDU tarafından
Yes but i tried with other chargers and original but i cant charge the device
Pietro Berton tarafından
Yes, Also I have this issue. How to charge it
mareesvaran046 tarafından
I have already gave the solution. Please check for dirt accumulation on the connector point of Fitness Tracker & charger. Try cleaning it with rubbing alcohol & pointed tooth-stick (please don’t use any metal object). Once cleaning is done try charging your device; hope this should solve the issue.
