Ana içeriğe geç
Service and repair information for the Huawei Mate 8, which was released in November 2015. It runs Android OS, v6.0 and sports a 6.0-inch display. In addition to a 16MP primary camera and an 8MP secondary camera, the Huawei Mate 8 also has a non-removable Li-Po 4000 mAh battery.
15 Soru Tümünü görüntüle
Does changing the battery also require us to change the screen?
I've been having battey charge drop problems. When I go to the Huawei service center they tell me that battery change will also require a screen change. (Without even checking my phone). They say that the battery comes with the screen. My screen is in perfect condition. Is it true that the battery change will also require a screen change?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
@slot1gamer @jayeff Thank you guys. It sounded silly to me as well when they said that the battery and screen both have to be replaced.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
Hi @alieffendi ,
Looking at the Huawei Mate 8 Pil Değişimi guide, it is not necessary to remove or replace the display.
If you decide to replace the battery yourself, read the comments at the bottom of the guide for a tip that may be of some help.
Puan 3
2 Yorum:
depending how you look at it, are you removing the screen or removing the back?? hmmmm
tarafından
Hi @slot1gamer ,
Fair enough.
I've amended my answer.
Cheers
tarafından
Yorum Ekle
No they are being dumb..
The battery is stuck to the mid frame with some double sided tape, this is a job a day 1 tech can do.
Puan 1
Yorum Ekle
Yanıtını ekle
Ali Effendi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 94
