Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Soru Tümünü görüntüle
Soru Kapandı
My iPhone4 doesn t work after lcd replace
Dear guys,
i had this problem: i replaced display and touch screen on my iphone 4 and saw all was good but after some hours i tryed to use charger and i had bad surprise: charger don t recharge battery and if i try to attack it to my computer it don t find it. So i tried to replace the dock connector and no luck, tryed to change cable , charger and battery and again no luck :(. So in your opinion what is the problem? what happened?
Best regards
Dan
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Does the home button work?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Most Likely you did something wrong when you replaced your display, did you mess with anything else BUT the screen when you replaced the display ? Try backtracking on what you did and reassemble your phone and try it again, you never know it you dont try.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
i tryed many time to reassemble it but no luck, i tryed also to use a recharger not apple and show the message "this charger it s no original" but not recharge too :(. Don t know what to do now.....
tarafından
Yorum Ekle
My experience says it can be the kabel of the charging port
it is fragile
Puan 0
4 Yorum:
i tryed to change the charging port connector but no luck
tarafından
That one [bağlı ürün eksik veya kapalı: IF182-009]
tarafından
yes that one
tarafından
i change display and all partsin my job and today the same problems. i changed display and touch screen on iphone 4 and after to have plugged and unplagged display into his socket in logic board the same problem. all the phone work right but it s impossible recharge it. Do exist a block that close the charge if some1 replace display many time or i m just unlucky?
tarafından
Yorum Ekle
did you make the connector the battery plugs into loose ?
http://www.iphonecentral.us/iphone-repai...
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 5,042
