Ana içeriğe geç
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Volume switch does not work
Before fixing the monitor screen with double-sided tape, the volume switch works, but if it is fixed with double-sided tape it will stop functioning. Could I ask the reason.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You’ll need to verify that the Volume Button flex is properly connected and secured and that the flex is not damaged in any way. Check out this guide, specifically Steps 36-40. The application of the double sided adhesive may be exacerbating a flex issue.
Bu yanıt yardımcı oldu mu?
Puan 5
4 Yorum:
Although there are neither breakage of parts nor looseness of screws.
tarafından
You would be surprised that these parts fail from just dropping the iPad it happens. You'll need to get that volume flex assembly replaced.
tarafından
Thank you for helpful information. By the way, why does it happen just by exchanging panels? Specifically, which part?
tarafından
Possibly the volume flex got damaged when cleaning the iPad housing of the old adhesive. It is the part that Minho linked as shown in the guide above.
I've done it once, when not being careful near the volume area when cleaning. It intermittently worked one of the buttons because they got damaged.
tarafından
Yorum Ekle
Yanıtını ekle
Shigeaki Niikura sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 110
