Ana içeriğe geç
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
20 Soru Tümünü görüntüle
iMac Display shows horizontal bars/lines
My iMac started to show strange horizontal bars (perfectly dividing the screen into 4 areas), with flickering lines. The colors of these bars are blue/black.
Adjusting the brightness cause the bars get less or more visible.
Replaced my HDD with an SSD 6 months ago without issues until now. I was reading about opening the iMac and damaging the LCD display connectors.
The display works perfectly when it’s connected to an external monitor, wired or via airplay.
Did any kind of tests, even Apple Service Diagnostics, no issues found.
Thanks in advance
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
What does an external display look like? If its clean then the display assembly is damaged, it the external show the same markings then the logic board has problems.
Bu yanıt yardımcı oldu mu?
Puan 2
8 Yorum:
As mentioned in my post, the external display shows a perfect image. Can you be more specific about the display assembly please? What is damaged specifically, the whole LCD? Thx
tarafından
Sounds like it was damaged in the process of taking it off then. Most of the time one see's bars when the display was not taken off correctly using the proper tools and technique. Here's the needed part [bağlı ürün eksik veya kapalı: IF174-035] and here's the guide to replace it.
tarafından
I did the SSD replacement myself following the iMac Intel 27" EMC 2546 Hard Drive Replacement guide and bought the same kit. Are you sure it's not possibly related with the display data cable, or it's connectors?
I'm asking to be sure because changing the whole LCD is really expensive, also idk why doesn't shows to be available for international shipping when I try to add to my cart (
tarafından
If you strongly believe the cable and or the connectors are damaged then lets take some pics so we can see and post them here.
The T-CON board on the back of the display is where I suspect your problem is located. As an example : 27" 2014 iMac T-CON board.
tarafından
I agree, but no, I cannot be sure. I will ask to iFixt if there some possibility to ship internationally the Display Assembly. Thanks Dan!
tarafından
3 tane daha yorum göster
Yorum Ekle
Since you can connect to an external monitor IMHO I think you are correct. It sounds like the LCD display connectors have been damaged. I’ve never repaired/replaced that but perhaps the iFixIt archives will have something? Good luck.
Puan 1
1 Yorum:
Yep, saw some. I guess I have no other way to open and try. Thx.
tarafından
Yorum Ekle
I seem to have the same issue. iMac screen is messed up but “clears up” after some time. Hooked up to external monitor no problem.
Brought my machine to Apple and they couldn’t 100 Percent give an answer. Computer is in working order except for the mysterious screen issue that comes and goes.
Nobody knows what to do.
Puan 0
1 Yorum:
Yep! Your internal displays T-CON board is failing!
Sadly, you'll need a new display iMac 27" LCD Display Panel & Front Glass Assembly (12/13) and here's the guide you'll need to follow iMac Intel 27" EMC 2546 Display Replacement
tarafından
Yorum Ekle
Yanıtını ekle
BVox sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 1,939
