Ana içeriğe geç
İlk olarak 2006'da piyasaya sürülen NeatDesk, ADF (otomatik belge besleyici) ve çift taraflı tarama özelliklerine sahip bir masaüstü belge tarayıcıdır. İlk sürüm versiyonu "ADF-070108" model numarasına, daha yeni olan sürüm ise "ND-1000" model numarasına sahiptir.
Scanner just went out
My neat scanner just went dead. Unplugged and plugged it in again; even plugged it into another outlet. Is there a reset button? Can it be fixed or is it not worth it? We had a power outage and when the power came back on it wouldn’t work. Could a power surge have burned out the power source in the scanner?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
If possible, it is always worthwhile to at least attempt to repair anything.
Not only is there the satisfaction of having done so, if successful, it means that in this case for a while at least it won’t add to the ever growing mountains of e-waste.
The resultant power surge that may have occurred when the power was reconnected after the outage could have burnt out components in the scanner,
Here’s a link to the ifixit NeatDesk™ Masaüstü Tarayıcı Devre Kartı Onarımı guide. This should be of some help in opening the scanner to initially do a visual inspection to see if there is any obvious electrical damage to the electronic components, such as burnt out surge suppressors, blown capacitors and blown fuses etc.
If you do see something (or even if you don’t) and are unsure, take some close up pictures of the circuit board and post them back here.
Here’s how to do this.
Mevcut bir soruya görsel ekleme
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
NeatDesk™ Desktop Scanner Görseli
Kılavuz
Zorluk:
Orta
1 hour
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Eileen Halverson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 575
