Ana içeriğe geç
Ice maker not working
Whirlpool Model WRX988SIBM00 refrigerator ice maker not filling nor dispensing ice. Water dispenses just fine. Have checked water pressure, have replaced water inlet valve to ice maker. Temperature appears fine as we have unplugged refrigerator to reset and are sometimes met with once cycle of ice cubes. Ice cubes will mysteriously appear once or twice every couple of weeks. Suspect it might be the infrared emitter board or the receiver board, but have no idea how to test them and unwilling to willy-nilly replace them for $400+ (emitter board around $80 and receiver board $300+) . Does anyone have any idea how to narrow this down and/or test the emitter and receiver boards. Many thanks in advance.
Bu iyi bir soru mu?
Puan 1
9 Yorum
You commented that you do not want to willy nilly replace a part without testing first. I understand that completely. But sometime you just can’t be certain. I had this same problem and went with RepairClinic.com because they offer full refund if the part purchased did not fix the problem. They also offer full guarantee on the part for one year.
I do not work for RepairClinic nor receive compensation from them. I’m just a satisfied customer.
tarafından Paylaş
I have the same problem with a similar model Whirlpool. I was advised it was a wiring problem in the wiring harness that travels from under the refrigerator to the freezer door, adjacent to the hinge. He repaired wiring but problem remained. I was told he has to order a new freezer door, which has a six weeks arrival time. (REALLY) I purchased an extended warranty which is covering door cost but I am concerned it is not door issue. Any recommendations?
tarafından Paylaş
Hi Tracey,
Yes, I was able to finally fix the problem. We replaced the whole ice maker assembly, but I don't really believe that was the issue as I still had the problem. Then we replaced the water inlet valve at the bottom of the fridge ( I had earlier replaced the more complex valve in the ceiling of the fridge but that had not done it either). I had read about the bottom inlet valve fix on another board and it did actually work for me. Hope it does for you as well.
Scott
tarafından Paylaş
Whirlpool French Door WRX988SIBM03 ice maker issue here.
Mine seems to shut off or very slowly make ice.
No error codes - Tests 56, 57, 58, & 59 are all good.
We think the issue may be the main control board so I just ordered one.
Here's the diagnosis.
I reset fridge using 3 different methods: unplugging, throwing circuit breaker, and turning off cooling.
None seem to remedy this issue with slow ice making.
Ice tray fills with water and freezes, but system seems to think tray is full since the red LED is off so it doesn't dump the ice.
Disconnect/reconnect plug in upper left door, the LED lights up and will harvest the ice eventually (depending on temp of ice/heater status, etc.)
Then LED goes out again disabling/slowing ice harvesting.
If I wait for ice, I can manually harvest using test 57 advancing SW3 once hearing the sounds of ice falling followed by water filling the tray.
Thus something is shutting off power to the IR level sensor dumb boards.
I say a main control board.
tarafından Paylaş
@scrowi14 Scott, your's seems to be the same issue as mine. My water system works fine and ice tray fills and freezes. Did your LED go out at all or was it always lit?
tarafından Paylaş
4 tane daha yorum göster
Yorum Ekle
8 Cevap
Filtre ölçütü:
Seçilen Çözüm
Scott Williams, in 34 yrs I’ve never replaced an optic sensor, This model has had several issues that have caused little to no ice. Before spending all that money do these checks. I’ve started with the easiest checks first
Get an exact temperature of the ice room. The ice maker wont advance if the temp. is above 9*F
Bypass the water filter by removing it and adjust the ice setting to MAX ICE or fast ice - turbo ice. Check ice production in 24 hrs. If you have ice then you need to replace the filter and flush the line at the water dispenser at least one gallon of water to remove air.
Clean condenser coils. Dirty coils cause refer temperature to rise, thus, effecting ice production.
Look for signs of frost on back wall of freezer and fresh food section. Remove food, and even the drawer so you can feel the back wall. If you see any frost on any walls, floor, ceilings, then you need to completely defrost the unit by unplugging, remove all food and leave doors open for 2 days. Once you plug it in, allow 48 hrs for ice production. If everything works fine, for a few weeks then ice slows again, you have an issue that many have had. Diagnosing the defrost circuit and all fan motors to find the issues.
Do these checks in the order I listed. Let me know what you find.
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
Thanks @ladytech. This always happens, but the ice is working again after unplugging. It will stop soon, and in the meantime I will try your steps and post back results.
tarafından Paylaş
Are the condenser coils in the lower back of the fridge? I found ice on the back wall behind the ice maker assembly, so I'm suspecting that I've got a defrost issue. Not convenient to defrost right now, but I will try that. When you say diagnose the defrost circuit, what do you mean? I will look for all fans - I think the only one I'm aware of is on the lower back though, right?
tarafından Paylaş
Scott, the condenser coils are underneath the refrigerator by the compressor. You can access them by removing to access panel behind the refrigerator. Some models you will need to remove the panel at the bottom on the front too.
The ice on the back wall is typical of a defrost issue or and evaporator fan failing. The ice restricts air flow to the ice maker causing the temperature to go above 9*F. The i/m won’t cycle over 9*F. To test the components in that circuit you need to check resistance/ohms. You need a multimeter. But you won’t be able to get to the components until all the ice has thawed. I don’t suggest to thaw with a blow dryer. The liner is thin plastic and melts very easy.
The defrost circuit has a heater, defrost thermostat (round disc type bimetal), a sensor and evaporator fan motor. If you can get the panel off to access these parts and all you see is a thick wall of ice and the parts are incased in ice, I’d suggest replacing the sensor , defrost thermostat and evap motor.
tarafından Paylaş
Scott, please disregard my last comment. I had the wrong model pulled up.
tarafından Paylaş
You have the i/m on the door. Your getting ice behind the ice maker, correct? If you pull the ice bin out do you notice frost/ice near the ice chute, where the ice drops out into your cup? If so, the ice dispenser chute door isn’t sealing good. You also have a seal around the access door to the i/m. There is a gasket where the refrigerator and door meet. That gasket is where the air from the freezer enters the ice room. If any gasket is worn replace it.
Do you notice frost/ice on the back wall of freezer? If so, then my earlier comment applies. The defrost circuit is behind the rear panel in freezer.
tarafından Paylaş
1 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
Cause 1
Low Water Pressure from House Supply
The home may have insufficient water pressure. The water inlet valve supplies water to the ice and water dispenser. The water inlet valve requires a minimum of 20 psi to function properly. Check the water flow and test the pressure to determine if it is at least 20 psi.
Cause 2
Ice Level Control Board
Some refrigerators use an infrared beam to sense the level of ice in the ice bucket. When the ice level reaches the top of the bucket, it interrupts the infrared beam. The control board then shuts off the ice maker. When the ice level drops below the beam, the control board signals the ice maker to make more ice. If the ice level control board fails, the ice maker will stop making ice. Ensure that the ice level control board is getting power. If the ice level control board is getting power, but the ice maker won’t work, replace the ice level control board.
Whirlpool Refrigerator Ice Level Control Board W10870822 $79.15
Ice Level Control Board W10898445 $316.10
Also try cleaning both the send and receive lens. To test use your finger and see if it is putting out a beam.
Monitors and manages the ice levels in your refrigerator ice maker. Görseli
Ürün
Whirlpool Refrigerator Ice Level Control Board - W10898445
$276.99
Monitors and controls the ice production process in your refrigerator. Görseli
Ürün
Whirlpool Refrigerator Emitter Control Board - W10870822
$138.99
Puan 3
6 Yorum:
The water pressure in the house is above 20PSI.
Ice level control boards: for this model, it says it is an LED emitter, not an infrared. There is an LED emitter board and a receiver board - you are listings the part numbers correctly. If this is truly an LED emitter, then shouldn't I be able to see a light beam if I place a piece of paper in its way with the door switch engaged? I don't see any beam. If it's an infrared beam isn't infrared beyond the human sight spectrum? How would I test that to see if there's an infrared beam?
tarafından Paylaş
@ladytech can you help with this one?
tarafından Paylaş
Hi @scrowi14 ,
Usually digital cameras can "see" infra red.
Try the following:
point the remote control from a TV towards the lens of a digital camera (even a mobile phone camera will work) and press and hold any button on the remote, you should see the IR light flashing at the end of the remote when looking at the camera's LCD screen.
Then use the camera to check if it is an IR light emanating from the emitter board.
tarafından Paylaş
I'll try later today. Thx for the suggestion.
tarafından Paylaş
It is LED, not infrared. I actually see it, red, periodically, just not all the time. Still unsure how to determine if it's a bad board.
tarafından Paylaş
Yorum Ekle
I have a similar fridge. It was one of the worst purchases I’ve ever made. The icemakers are prone to failure and sometimes it makes sense to replace it. But before you do that, make sure you check the obvious and other components before replacing it. I doubt there’s anything wrong with the controller. If it fails, then usually a bunch of other things will fail too. As for sensors, most ice makers have sensors built into the actual ice maker mechanism.
First, check the ejector arm. Sometimes it gets stuck from ice or it can get dislodged or misaligned. Make sure it moves freely. This is an easy check.
Second, reset the refridgerator using the front panel, instead of unplugging it. Once reset, perform a diagnostic to check for any error codes. Also, check the temperature of the icemaker from the diagnostic panel and your own reading using a thermometer. You can also just fill the ice tray with some water and check if it freezes in a few hours.
Third, make sure there’s no ice build up in the back of the ice maker’s compartment. If you see ice, turn off the icemaker using the front panel for several hours. If the ice has cleared, then turn on the ice maker.
Fourth, if you can’t find anything wrong, then it’s time to purchase or try to repair the ice maker. As a strong suggestion, don’t pay for a branded part. It makes no difference in quality and you can save a ton of money. A new aftermarket icemaker is around $50 or less on eBay or Amazon.
Here’s the manual if you need help performing the front panel.
https://www.searspartsdirect.com/partsdi...
Puan 1
Yorum Ekle
Bud, I think your maker is the first thing thing to replace…it creates demand and the emitter controls it when its full….
Update (07/12/2019)
emitters have come down in price significantly and there is nothing wrong with the generics….Whirlpool Refrigerator Ice Level Control Board - W10757851
Monitors and regulates the ice level in your refrigerator's ice maker. Görseli
Ürün
$240.99
Puan 0
Yorum Ekle
The most likely cause is the rotating mechanism in the icemaker….its also the simplest to replace. Just determine model number and its an easy order…..check if yours is narrow one (5 cube) or full width (8cube). Then follow these instructions
https://www.youtube.com/watch?v=2DdUW9Il...
when your part arrives…..the rotating mechanism is plastic and can break easily if for some reason there is an obstruction in the emptying into ice reservoir process.
Puan 0
Yorum Ekle
The most likely item to fail is the ice making unit as the rotating mechanism wears out. When that happens all kinds of weird ice making behavior can occur. Not the infrared emitter or the water valve or the wiring harness…they have no moving parts…..I disagree with the door replace diagnosis.
Has the ice maker ever been replaced?
Puan 0
Yorum Ekle
I have a similar issue. The ice level emitter doesnt work. Only time it works is if I unplug and plug back the fridge. However, it works for 5 min then goes off. It also works in maintenance mode, but when I go back to normal mode the red light shuts off. I'm starting to suspect a relay in the main board.
Puan 0
2 Yorum:
I have same issue and can’t figure it out. Unplug the optic board, plug it back in and red light turns on for a few minutes and then goes out. Won’t come back on unless you unplug the optic board and plug back in again.
tarafından Paylaş
Same issue here. replaced the entire ice maker and both boards. Still same issue red LED stops after a minute or two and the receiver thinks my empty BIN is full so it never ejects the made ice or calls for more.
tarafından Paylaş
Yorum Ekle
The entire issue is due to the inlet hose not being above physically the inlet hose going into the refrigerator. My mom's did this for months. Somebody came by charged her 60 or $100 to fix it came back said they fixed it it wasn't fixed. I noticed when it was first installed the inlet from the water source was put in a way to where I was at the top of the fridge. Now I noticed it no longer was. I raised up the inlet hose about 2 ft above the line that was going to the fridge and within three or four hours my mom asked what did I do to fix the ice machine. Hope this helps all who is dealing with this. I literally screwed a hook into the wall and used a bread tie to hold the line in place. Fixed. May your drinks be cold. :)
Puan 0
Yorum Ekle
Yanıtını ekle
Scott Williams sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 105
Her zaman: 59,786
