Home screen display problem
I just replaced the cracked screen on my ipad3. It turned on okay but the home screen is not displaying correctly. There is a thick black line down the middle of the screen. One half of the screen is displaying fine and the other half is distorted. Icons seem to be all working. I’ve check my connections a few times and all seem to be inserted correctly. I can figure out what is wrong.
Update (06/30/2019)
Attached is an image of the screen. If it is a damaged connector is that an easy fix? Thank you all for your help.
Bu iyi bir soru mu?
1 Yorum
Can you take a close look at the LCD connectors on both the ribbon cable and logic board? They may have gotten damaged when being reconnected.
da stumer tarafından Paylaş
