Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Soru Tümünü görüntüle
How to turn on MacBook without using the keyboard or trackpad
My laptops keyboard and trackpad stopped working a long time ago but recently I’ve started using a separate keyboard and mouse for it. Today I shut down the computer without thinking and now I have no way to turn it back on!
Is there anyway I can power it up without having to use the built-in keyboard and trackpad???
Bu iyi bir soru mu?
Puan 0
2 Yorum
Can you give us your exact model so we can help you further. Use your S/N here EveryMac - Look up let us know which it yours.
tarafından
it’s an Apple MacBook Pro "Core i5" 2.7 13" Early 2015
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here’s a picture to the power pads for your system
Just short across the two pads briefly and the system should restart.
From the sounds of it your keyboard is in need of replacing. You might find replacing the uppercase to be an easier repair MacBook Pro 13" Retina (Early 2015) Upper Case Assembly (you’ll need to get the one that’s still in stock) and here’s the guide MacBook Pro 13" Retina Display Early 2015 Upper Case Replacement Here you can transfer your trackpad over and either transfer the battery or get a new one following this guide MacBook Pro 13" Retina Display Early 2015 Battery Replacement
MacBook Pro 13" Retina (Early 2015) Upper Case Assembly Görseli
Ürün
$269.99
MacBook Pro 13" Retina Display Early 2015 Battery Görseli
Kılavuz
Zorluk:
Zor
45 minutes - 2 hours
MacBook Pro 13" Retina Display Early 2015 Upper Case Görseli
Kılavuz
Zorluk:
Zor
3 hours
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
If you disconnect the battery connector then plug in the magsafe it will start booting. You can then reconnect the battery connector.
Puan 1
2 Yorum:
As we don't know the series this may not work. The older Unibody systems need to use the power pads and some early retina models have them too.
tarafından
Thanks Dan that is good to know.
tarafından
Yorum Ekle
Yanıtını ekle
stacy rodri sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 52
Her zaman: 2,576
