Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Soru Tümünü görüntüle
Can you install a blank SSD if your old SSD has failed?
So my old SSD failed so I need to put a new one in.
I don’t care to have a backup, I just want to start new so can I put the new blank SSD in the system and download the OS over WiFi directly without an external hard drive?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Thanks for asking Luke! If you don’t need any data swapped then you should be able to install a new ssd into the device and use internet recovery to reinstall Mac OS by pressing the command key + R at the same time but keep in mind that these devices use a proprietary connector and it’s not a normal m.2 or sata connection.
Best regards
-Activoid
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
So I can just put the new one in then where the old one was right and it should work so I shouldn’t need any connections?
tarafından
Yes, Refer to this guide on ifixit MacBook Pro 13" Retina Display Early 2015 SSD Replacement . But, remember the drive slot is proprietary.
tarafından
Yorum Ekle
Yanıtını ekle
Luke James Langpap sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 175
