Ana içeriğe geç
Model M8541 / 5 or 10 GB hard drive / scroll wheel physically turns
29 Soru Tümünü görüntüle
Soru Kapandı
no iTunes mount
My iPod 1st generation still runs, still charges, still . . . lives. It will mount as a Device on iTunes, however.
Performed all the reset routines, the internal diagnostics, tried different machines and cables. Examined and cleaned the pins.
Any ideas? Taking it apart to look for bad solder right now.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
You said "It will mount as a device..." - did you mean to say it will NOT mount? And presumably you are using a Firewire cable, correct?
tarafından
Yep, my typo. Will not mount via Firewire on any computer. Tried straight 400 and 400-800 cables.
It does charge, it does play.
I disassembled it. The solder joints on the logic board look OK at the FW port.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Does the iPod show up in Disk Utility? Sometimes a disk that won't mount will show up in Disk Utility and can be mounted from there. (You could also run disk repairs on it there, which might clear up the problem.)
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
DiskWarrior and Disk Util won't mount the bugger. Thanks, Mr 790.
tarafından
Yorum Ekle
Puan 0
Yorum Ekle
maybe try erasing/reformatting the drive on disk utility and then try to connect and restore on itunes.
Puan 0
Yorum Ekle
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,352
