Ana içeriğe geç
İlk olarak 2006'da piyasaya sürülen NeatDesk, ADF (otomatik belge besleyici) ve çift taraflı tarama özelliklerine sahip bir masaüstü belge tarayıcıdır. İlk sürüm versiyonu "ADF-070108" model numarasına, daha yeni olan sürüm ise "ND-1000" model numarasına sahiptir.
Why does it Scanning slow?
It was scanning at a fast pace and now it scans really slow.  Does anyone know how to fix this?  What should I be checking?   I have cleaned it thinking it might be dust but nothing.
Any suggestions are appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Hi @nani11 ,
Does it do this when using the scanner's button controls, the Neat scanner software in a computer connected to the scanner or both?
tarafından Paylaş
@jayeff
I press the PDF button to scan my documents or receipts and it scans really slow. I have a video but sure how upload it for you. Tk u for helping me.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @nani11 ,
Is the scanner connected to a computer?
If so try re-calibrating the scanner and check if this resolves the problem.
Here’s a link to the section in the manual (is this your model?) that shows how to calibrate the scanner. Scroll down to “Calibrate your scanner” and then click on the Next page link to view the process.
Here’s a link that shows how to add media to your question on ifixit.
Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
@jayeff Still after the calibration
tarafından Paylaş
Hi @nani11 ,
Can you try scanning from a computer to see if it is still slow or not?
Just wondering if you can maybe change the dpi settings for a scan using a computer which maybe you can't when using the scanner controls, to see if this makes a difference in scan speed or not.
Usually the higher the dpi the longer it takes to scan as it produces a more detailed scan.
If it makes no difference it could be a drive motor problem in the scanner
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Jan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 738
