Ana içeriğe geç
The HP Color LaserJet Pro MFP M277dw is a color laser printer with scan and copy functions. It has a model number: B3Q11A
13 Soru Tümünü görüntüle
Where does small black plastic fuse holder on the fuser assembly go
I had to take apart the fuser unit on my LaserJet Pro M477 to remove a bad paper jam. In doing so a small 1” black piece of plastic fell out containing what appears to be a fuse (looks a little like a thick SD card). I can’t figure out where it goes. I dont see anything that the contacts on the fuse cartridge would connect to.
Any help (or a picture) on where this goes would be appreciated.
Below is a picture of the part. I believe the blue component inside it is a fuse.
Aprox dimensions are 1” x .75”
Bu iyi bir soru mu?
Puan 0
2 Yorum
Might want to add a pic to your query so that the component in question can be identified easier.
Adding images to an existing question
tarafından
May I know how did you take apart the fuser unit? I think I have some paper stuck inside the printer at rear area where the fuser unit is blocking and it's impossible to reach inside with my fingers... I don't really know how to go about removing the fuser unit so I hope you can help me somehow.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Figured it out
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
good for you
tarafından
Yorum Ekle
En Yararlı Yanıt
Sounds like the Duplex Model. That’s #6 in the upper left hand corner of this parts diagram, and it goes into the fuser:
https://printcopy.info/?l=en&mod=pc&bran...
Puan 2
1 Yorum:
I dont think that is the part (#6). prop man had a good idea, to post a picture of the part. I wont be in the office tomorrow but will add a pic on Friday unless someone else has a suggestion before then
tarafından
Yorum Ekle
Yanıtını ekle
Jack sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 402
