Takes over 2 minutes to boot up, lagging while opening apps .
My Macbook Air, 2017 suddenly started to lag and freeze. The bootup takes over 2 minutes. Youtube wont run on Safari. I ran the the TG Pro test and every sensor seems to
Update (10/02/2019)
Bu iyi bir soru mu?
6 Yorum
Have you tried booting to Safe Mode? Is it still lagging if you do? https://support.apple.com/en-us/HT201262
Jonah Aragon tarafından
Erased and Reinstalled my macbook over 5 times… Still no avail..
Safe mode doesnt do any good either. tried smc, pram,nvram reset too...
Ojaswi Jaiswal tarafından
@Ojaswi Jaiswal Please select the CPU tab, in the screenshot you added we see the use of RAM which is not so meaningful. Do not forget the Coconut battery screenshot, just in case, take the screen after you click on "battery info" button.
arbaman tarafından
Done as requested
@Ojaswi Jaiswal Battery and sensors seem fine from the further info you supplied, as well as CPU which seems not to be throttled at all. In my opinion data are processed fine, no bottlenecks apparently. I agree with @rav_taylor and I'd also try how things work through the Usb port..a faulty flash drive or data transfer from the drive to the Cpu seem to be involved here and that's where I would focus. Just my 2c.
arbaman tarafından
1 tane daha yorum göster
