Ana içeriğe geç
The Nissan Rogue is a compact crossover SUV (sport utility vehicle) produced by Nissan, a Japanese automaker. The Rogue was first released in 2007 for the 2008 model year.
Replace blower fan motor
How to replace the blower fan motor on a 2011 Nissan rogue
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Were is the location in heater blower
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @islandboy99 ,
Here’s a link to the 2011 Nissan Rogue (S35) Service Repair Manual
Here’s an image taken from the Ventilation System section of the manual that shows the procedure to remove/replace the blower motor.
(click on image to enlarge for better viewing)
The other repair sections referred to in the removal procedure are as follows. The number after the dash is the page number in the section e.g. IP-13 = Instrument Panel section page 13
IP = Instrument Panel
MWI = Meter, Warning Lamp & Indicator
VTL = Ventilation System
HAC = Heater & Air Conditioning Control System
BR = Brake System
It is easier if you download the individual repair section and then view them that way.
At the bottom of the Document page that opens for each section there is a download link. Here’s an image to show where it is.
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Hello.
Remove the Driver Brake Pedal and also will help if you remove the Gas pedal.
After that youll lay on your back with flash light youll go underneeth the dash. on your left upper side youll se the blower motor.
Remove a screw top left of the blower motor.
Remove plug. ( it can be pain cuz you are upside down)
You need to twist the Blower Motor Left
This is the challenge here. After you remove the Blower motor it will not come ease. Theres is a Dashboard in your way a steering shaft. You need to find a way you remove the old (bad ) blower motor. Be creative.
After removing the blower motor(old) you need to find a way to the new one same way with you Braking the blower motor. its not easy repair.
Be patient.
Then reveres everything.
This is the way that i did it. :)
Puan 2
Yorum Ekle
Yanıtını ekle
Paul baron sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 38
Her zaman: 5,007
