Ana içeriğe geç
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
20 Soru Tümünü görüntüle
screen fades to black from left to right
my Samsung 60” led tv un60eh6000fxza picture fades to black from left to right but still has sound. If I shut it off and turn it back on I have a picture and sound but it fades to black after a few minutes.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @vshanewilk ,
If the TV is still covered by a warranty, get it fixed under warranty
If the TV is no longer covered by the warranty, try the following.
Disconnect the power from the TV and then remove the back cover.
Then disconnect the cable that runs between the power board and the mainboard.
Reconnect the power to the TV and switch on the TV.
All the TV panel backlights should turn on and stay on. There will be no picture as the mainboard has been disconnected.
If they don’t stay on check the voltage at the backlight cable connector on the power board.
If it reads no or low voltage then there is a problem with the power board.
If it reads high voltage (180-300V DC) then there is a problem with the backlights. There is either a faulty connection somewhere between the power board and the backlight array or some failing backlight LEDs
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I think it’s a power supply board issue, maybe something to do with the capacitors
Puan 0
Yorum Ekle
It could be the power supply as previously suggested; it could also be the backlight circuit as well. If the LED backlight driver circuit is weak and failing, this circuit is most likely your culprit. Bad capacitors could be at fault in either circuit.
If you’re inclined to do so, take the back of the TV off and look at the boards; check for capacitors that have domed or swollen tops, and might be leaking. If you post pictures of what you see, that MIGHT help others help you as well.
Puan 0
Yorum Ekle
This 100% is a t-con board issue, it's a very common issue with this model, problem will be finding one however on ebay there are several companies offering a repair service. Hope this helps
Puan 0
1 Yorum:
Larry Bjerke how do you figure this "fades to black from left to right " is a T-con board error? Which part of the T-con circuitry? Why would it fade like this?
tarafından
Yorum Ekle
Yanıtını ekle
vshanewilk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 6,492
