Ana içeriğe geç
Mate 20 from Huawei announced in October 2018 in London. Global model HMA-L29 is available with 4/6 GB RAM and 64/128 GB storage. Triple camera setup, 4200mAh battery, and rear-mounted fingerprint sensor.
Is my phone hard bricked?
Hi, all just wondering if my phone is hard bricked or not since I can’t find any information on my specific device it won’t turn nor vibrate the red light goes out and return after 10 seconds press of power button and the hard rest process. Is there any solution to it or is the phone dead?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Try this link and check if you can force flash the stock ROM
Here’s a link to the available ROMs
Bu yanıt yardımcı oldu mu?
Puan 2
8 Yorum:
Hi, so my phone is hard bricked even though I didn't mess around with the software?
tarafından
Also, How will I be able to flash ROM when there no connection to my pc?
tarafından
Hi,
Does the phone indicate that it is charging properly when the charger is connected?
You don't use a PC connection.
When you do a "force flash" the firmware files are stored on a SD card which you have pre-loaded (load into the root directory of the SD card) from a PC or phone or whatever and then you insert the SD card into the phone.
It is all there in the instructions
tarafından
well, the condition regarding the charging thing it's weird the light comes on but now it flashing and when holding the power the phone vibrates but then the light goes back to solid again furthermore when it vibrates the screen comes on showing low battery but that's all once the solid light comes on the phone goes back the original condition black screen and no response.
Thank you for your help.
tarafından
Hi,
What happens if you just connect the charger and do not press any buttons?
Does it charge smoothly up to full charge or does it stop charging, start and stop etc?
Have you tried either starting the phone or doing a hard reset with the charger connected in case it is a faulty battery that is the cause of the problem?
Can you get into the phone's recovery menu area OK with the charger connected and switched on?
tarafından
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Tony Vox sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 29
Her zaman: 2,490
