Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Soru Tümünü görüntüle
Backlight of iPhone 4 is dim after submersion
I took my iPhone in a lake a while ago, put it in rice, and tried to turn it on. It didn't work, so I ordered a battery from here, and it started working again. The only problem was the LCD backscreen was very very dim. I'm wondering how I can fix this problem.
Bu iyi bir soru mu?
Puan 0
1 Yorum
Okay, my iPhone was submerged about a month ago. It wouldn't turn on at all and I put it in rice for about a week, and still no luck. So, I bought a new battery for the iPhone and replaced it. Luckily, the iPhone turned on, and I could see that the iPhone was up and running, but the screen was EXTREMELY dim. I had to use a light source (the beams coming off it) to FAINTLY see what was on the screen, but it was on!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Before you do anything else please follow the ifixit water damage guide.
Electronics Water Damage
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
tarafından
Yorum Ekle
Put the phone's logicboard in IPA, this removes any corrosion and may even fix this
If that dosen't fix it, you will need a LCD/digitizer assembly
The backlight is in the screen, there is also a small chip that shorts sometimes and will need to be replaced, so look for a burnt or shorted chip under the shields, in fact, remove them for the IPA cleaning
Want more info?
http://forum.gsmhosting.com/vbb/archive/...
Puan 0
10 Yorum:
Nick please take more than 1 minute to read and answer a question. You probably would give better answers that way.
tarafından
is the backlight part of the lcd or is is a separate coil like on the 3gs?
tarafından
good job on the editing
tarafından
i thought so..was just trying to get nick to give a more thorough answer
tarafından
Oh I see like mentoring the little grasshopper...:-) sorry for butting in....;-)
tarafından
5 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
chadderbox25 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 3,387
