Ana içeriğe geç
Repair and disassembly guides and support for dish washing appliances.
707 Soru Tümünü görüntüle
GE GDT580SMF5ES will fill but it does not start.
Hey friends, I’ve got a GDT580SMF5ES GE dishwasher that today started doing this
Press start (all cycle options same symptoms) it fills with water. Then it just sits. And sits. And sits until eventually after what would be the cycle spot to drain, and it drains as usual.
Any ideas? Any more info I can offer to help diagnose.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum
Hi,
Check behind the kickplate (toeplate?) to see if there is a 'tech sheet" taped on there.
If there is it should show how to get into the diagnostic mode for the dishwasher so that all facets of the dishwashing cycle can be tested.
It could be that the wash pump is not operating since from what you said it seems to "step" through the cycle to the drain point. Can you hear a humming sound when it just sits there?
tarafından
There isn’ta tech sheet but I think I found one and it really just showed operating normal in cycle
It never sounds like the wash pump kicks in. No hum or the normal signs.
tarafından
Hi,
If you have a DMM and you know how to use it when testing for potentially lethal voltages then you may have to check if voltage is being supplied to the wash pump (aka circulation pump).
If there is mains supply voltage at the pump terminals when the dishwasher should be washing the dishes and the pump is not operating then there is a problem with the pump motor. If no voltage then there is a problem with the control board or the wiring from the control board to the pump.
Be safety aware if you go to test for this voltage. If you don't know what you're doing then don't do it! It's not worth it. Call an expert
tarafından
Thanks I assumed that was the best recourse for testing so wanted to be sure before I go to that I’ll pull it out and work on it with a little room to spare for safety
tarafından
Did this ever get fixed? I have the same model and the same exact issue.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @Chris Want,
If there is no response from the OP then if you wish to purchase the service manual it should help you to find out what's wrong.
It details how to run and decipher the dishwasher's diagnostic program and it also has wiring diagrams etc.
The service manual (aka mini manual) for the dishwasher is GE part number 31-30705 but unfortunately I cannot find a free download online.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
jadyer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 103
