Ana içeriğe geç
The charger causes my laptop to heat up fast and lag(p158sa)
Whenever i plug in the charger in my laptop i get enormous frame drops and i notice my laptop get hotter then usual. My laptop also loses charge rapidly. I can only last about 30min-45min depending on what i’m playing and sometimes only 1h if im doing anything else. Need help.
Bu iyi bir soru mu?
Puan 0
9 Yorum
check if you have any spyware (that mines for bitcoin)? Some of them are intelligent that they start mining only when connected to power.
tarafından
@bmx2019 i recently reset my laptop so i don't think what was it. Thank you for your response!
tarafından
is it only during gaming? I know a lot of people install cracked games - may even contain spyware.
1. May be slowly disassemble laptop
2. Clean inside
3. Look for battery if it is swollen
4. Just have a clean windows install
5. Do not install weird boosters, RAM enhancers etc.
6. use it for a few days. post here
tarafından
@bmx2019 Hey i didn't replace my battery yet but i was able to fix the lag
by constantly forcing my laptop at max cpu speed at all times by using the "intelppm" service in the registry.
Will this have any effect on my laptop?
tarafından
me editing the registry has actually affected my laptop and stays at about 2.60 GHz cpu speed if i turn it on with the charger plugged in but goes back to 0.88 GHz if i unplug it and plug it back in
tarafından
4 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Check that the charger’s output voltage is 19.5V DC
If it is then the laptop heating up and the battery lasting for less than 1 hour appears to indicate that the battery is failing and needs to be replaced.
Try replacing the battery and then see if the problem is still there.
Here’s the maintenance and service guide for the laptop, taken from this webpage
Scroll to p.65 to view the steps to remove/replace the battery.
The battery part number is 756743-001.
Search online using the part number only in the search term of your browser, to find suppliers of the part
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Thanks I will try that
tarafından
tarafından
tarafından
@jayeff
works thanks
tarafından
Yorum Ekle
Yanıtını ekle
TGG Gamer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 23
Her zaman: 853
