Ana içeriğe geç
12.1" netbook has an AMD E450 APU running at 1.65 Ghz, Radeon HD 6250 graphics, 1366 x 768 screen resolution, release in April 2011.
2 Soru Tümünü görüntüle
Asus 1215B does not charge the battery.
Hi, I have a problem with my Asus. When I plug in the power supply, the battery doesn't charge. The power supply has the correct voltage. I'm attaching the BatteryMon screenshot.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
If it’s an older laptop, most likely the battery will need to be replaced. Batteries are consumable items whether it’s a TV remote or a car battery, it’ll need to get replaced at some point.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
BatteryMon shows a voltage of ~7V to 8V and the battery should be 10.8V. So it's probably due to the battery?
tarafından
Most likely a dead cell then, so yes a bad battery. And voltage is a measurement of charge, not capacity. A bad battery can show gold voltage but as soon as you put a load on it, that voltage can drop.
tarafından
Yorum Ekle
hi
you need to replace laptop battery
Puan 0
Yorum Ekle
Yanıtını ekle
Jan Kowalski sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 398
