Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
1200 Soru Tümünü görüntüle
3014 error code after water damage
my iphone stay in recovery mood since it falls on water and open itself and shutdown by itself many times .. i think its an internal damage .. how has the The solution please ..
Update (05/04/2020)
I went to repair stores for phones and they said:
your iphone is damaged forever you we cant fix it !
and during corona virus the apple service in my country are locked
and all the professionals mobile phone repair service in my city think it is damaged for ever
i started searching for the error code 3014 .. on YouTube and i have find this video
https://www.youtube.com/watch?v=w2yw79uM...
i have done everything in that video and my iPhone is back again with all my dear pictures and videos
but new problem is up! the face id does not work because its damaged because of the water.. so i have ordered that part from here
iPhone X Earpiece Speaker and Sensor Assembly
but i’m waiting for this sensor to put it on my iphone and i will say if the face id works again if i put the new sensor.
iPhone X Earpiece Speaker and Sensor Assembly Görseli
Ürün
$39.99
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Try putting the phone into DFU and doing a restore. Also try it on another computer, or with 3utools
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @glfaisal
To possibly get your phone working correctly again you need to clean it properly first, by dis-assembling it and using Isopropyl Alcohol 99%+ to clean all the affected parts as outlined below.
Once you’re satisfied that it has been cleaned properly, test the phone and check what happens
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone’s operating design and could damage the components. The corrosion is ongoing until it has been cleaned away
First do not charge or try to turn on your phone and then remove the battery so as to minimize any further damage.
Next you need to dis-assemble the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is <70% IPA, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. You will most probably also have to remove any shields covering the components as water may have got in under them as well.
Here is a link to the ifixit iPhone X guides, which may be of some help.
Hopefully after you have done all this it might possibly work correctly again.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
thank u for the advice its helpful
tarafından
Yorum Ekle
Hey, the new sensor will not help you get Face ID back, because it is not paired to the phone. If you want Face ID to work, you have to swap the flood illuminator module over to the new cable. This requires some skill and a hot air gun. Since the professionals in your city cannot help you, you could either send the phone to someone like iPad Rehab /STS Telecom (be sure to tell them that you just need the cable fixed) or install the new cable (keep the old one safe) and live without Face ID for now.
Puan 1
2 Yorum:
Alternatively, you could try and fix the cable. Clean it really well with rubbing alcohol and see if it works
tarafından
i will try and search for solutions maybe it's going to work maybe not .. they have telling me.. they can't fix my iphone but really nobody knows until i try .. maybe yes the new sensor not gonna get face id back but maybe i can discover something can make it work .. not giving up .. i didn't study technology im a Veterinarian Dr.. but im strong and resourceful and
i’ve accomplished way harder ..gonna figure this out .. soon i will update this page with results .. Nothing is impossible
tarafından
Yorum Ekle
If the isopropyl alcohol doesn’t fix it or you don’t have it due to a pandemic, you can mail it in to Jessa Jones (iPad Rehab). If you do have isopropyl alcohol, then take the logic board out, soak it and with a tooth brush, just scrub it.
Puan 0
Yorum Ekle
Yanıtını ekle
faisal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 258
