Ana içeriğe geç
Repair and disassembly guides for electronic keyboards.
214 Soru Tümünü görüntüle
Where would I be able to get the batteries part fixed on a Keyboard?
I have a Yamaha PSR F51 Piano Keyboard. The last time I used batteries in it, it worked fine and that was maybe just under 2 years ago. Since then I have continued to use the plug socket. More recently I wanted to use the batteries again, I put in the batteries and the Keyboard wouldn't turn on, I tried with different batteries it still wouldn't turn on. Is the batteries area knackered? Can it be fixed? Can it be replaced? Is it worth it and where can I get it fixed if possible? I am not someone who can just take electrics apart myself.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Since the keyboard works with the AC adapter connected it most probably is either a bad battery connection or a broken wire leading from the battery compartment.
Just verifying that the batteries were inserted correctly.
Here’s an image that show the battery layout for the keyboard.
(click on image to enlarge for better viewing)
The batteries are connected in series configuration in the battery compartment so that their combined voltage equals 9V.
Check that the spring connectors in the battery compartment (green) are exerting enough pressure on the battery so that the +ve end (other end of the battery shown in blue) is being pushed firmly into its’ connector so as to make for a good electrical connection.
Also ensure that the connectors are clean and bright and shiny and not corroded etc. Do not use any liquids to clean the connectors surfaces as you don’t want the liquid to get into the electronics of the keyboard. Try using an eraser to clean the contact surfaces.
If still no good the keyboard would have the opened and the problem further diagnosed.
Since you say that this is not something that you can do, perhaps you may know someone who is handy at fixing electronics who could fix it for you as it shouldn’t be that difficult. Otherwise contact a reputable, professional electronics repair service and ask for a quote.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Thank you for you're reply it was very helpful. I did put the batteries in correctly each time without it being able to turn on. I have been looking at musical repair shops near me. Hopefully it can be fixed as I'm not ready to look into buying a another Keyboard for the time being.
tarafından
Yorum Ekle
Yanıtını ekle
Lizzie Listens To Music sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 194
