Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Soru Tümünü görüntüle
Black Square on Left side of LCD
Hello guys,
So i have this MacBook Pro 15’’ 2014. The LCD is defective with a black rectangle of the left side of it. It didnt suffer any damage at all.
I was wondering if it could be a bad signal instead of a bad LCD because of the shape of it (its a perfect black rectangle from the left border and onwards on the LCD).
So far ive discarded a bad motherboard (tried another LCD) and bad LCD cable (switched cables).
Thank you very much.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Can you post a picture or two what you are facing so we can see Adding images to an existing question
tarafından
Ok just did, thank you so much.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Think of the display as a spreadsheet with columns and rows. Each one is a line that weaves across to a given cell which is lit to not. So if the column lines are cut then all of the lines effected are not lit. Thats the case here the display assembly is damaged! You’ll need to replace it.
I’m not sure I follow your actions as the logic board or display cable wouldn’t cause this.
Sadly, this display assembly is in short supply as people are not given up their systems! Here’s a link to the iFixit part which is out of stock 'MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly and here’s the guide: MacBook Pro 15" Retina Display Mid 2014 Display Assembly Replacement
MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly Görseli
Ürün
$319.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Juan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 187
