Ana içeriğe geç
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Soru Tümünü görüntüle
Service battery error on Unibody 2010
Im getting a service battery error, ive tried two new batteries and im still getting it. I have a 2010 Macbook unibody. Model A1342.
in coconut
Current Charge 3259mah @ 65%
Full Charge capacity 5000mah
Design Capacity 6600mah
Cycles 1
Update (06/23/2020)
https://i.ibb.co/fXZWJsh/Screen-Shot-202...
Battery made by Dynapack Was built on 4/20/20
https://i.ibb.co/HhxjQND/Screen-Shot-202...
https://i.ibb.co/1TY86pF/Screen-Shot-202...
https://i.ibb.co/pr4hqg8/Screen-Shot-202...
Heres a pic after its charged to 100%
https://i.ibb.co/qgDZHnP/charge100.png
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum
Who's battery are you using?
Also, it would be helpful to see the CoconutBattery output. Ideally, one with the battery under charge around ~80% with the charger plugged in and a second after the charger was removed for a good 3 minutes.
Post a snapshot of the main app window of each Adding images to an existing question
tarafından
@Walt Berger - What does it look like charging?
tarafından
Im letting battery get down to about 2%, then im gonna fully charge it. Ill get back to ya on how it does charging, make sure i take a screen shot. Thanks for helping.
tarafından
The battery went from 75.3% to 75.8% after 3 charges (cycles). Weird, ill look up logic board and test some things. Stinks love this laptop. Got 2.4ghz Duo, 16gb ram, 500gb SSD. Thing for what I do is perfect.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I think this is a weak battery. I would get an exchange.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
But two batteries from two different places ? Both batteries did the same thing.
tarafından
@Walt Berger - Are you using a REAL Apple charger?
If you are using a knockoff then the comparator logic can get damaged on the logic board. I don't see that here but that's all I can think of.
tarafından
Is their a way of testing the comparator logic on the board ? If both batteries did it, seems to me I damaged the logic board. Just weird I had another A1342 with same brand battery as im using currently without any issues.
tarafından
You'll need to find a set of schematics and board view drawings to trace out the logic. Search for your logic board 820-2279
tarafından
Yorum Ekle
Yanıtını ekle
Walt Berger sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 93
