Ana içeriğe geç
21 Eylül 2018'de piyasaya sürüldü. A1921, A2101, A2102, A2104 Modelleri vardır. GSM veya CDMA / eSIM veya nano-SIM / 64, 256, veya 512 GB / Gümüş, Altın, ve Uzay Grisi seçenekleri mevcuttur. ("iPhone 10 S Max." olarak telaffuz edilir)
375 Soru Tümünü görüntüle
Can I do a front glass only replacement at home?
I don’t want to spend a lot of money on a new display when my one works perfectly fine, the only issue I see is needing a OCA LCD Glass Vacuum Laminator Machine but theyre expensive, is tehre any way to do it without them
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You have a premium phone that cost a thousand plus dollars when it was new and there’s a reason for that and apple certainly didn’t use cheap parts to make it. Because that phone uses an OLED panel, glass only repair on them is near impossible without thousands of dollars in special tools you’d be better off replacing the whole screen assembly like every other cellphone repair shop would do, such as myself. It’s unfortunate that you broke your device but by trying to cheap out on the repair isn’t going to make it any better. However, you can do the repair yourself and if you really don’t want to pay a whole lot to fix it, you could order an LCD replacement screen rather than an OLED. But there are a few caveats to using an LCD. It has increased energy draw compared to OLED, which can impact battery life and you do run the risk of damaging the display connector because it’s not designed to handle such a high current draw. You can order them from mobile sentrix for around $85 plus shipping and tax but it doesn’t include tools.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
If you need to ask, you can’t do it.
If you want to do this kind of DIY repairs to save money, you’ll usually end up spending even more than buying a brand new phone.
Unfortunately above rules are very common in Apple DIY repairs.
Puan 1
Yorum Ekle
Or find a shop that will do the job for you, I think if you let them do only glass refurbish on your original screen it won’t cost you a arm and a leg. Glass only repair is possible for around €75,-.
Puan 0
Yorum Ekle
Yanıtını ekle
mosminecraft4 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 328
