Ana içeriğe geç
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
139 Soru Tümünü görüntüle
Electrolux/Frigidaire combo beeps 3 times randomly constantly
Just curious if anyone would know why my Frigidaire stackable Washer/Dryer model FFLE3911Qw0
Beeps 3 times randomly and it does it all the time. everything seems to work just fine
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
6 Yorum
My Frigidaire Washer Dryer Combo FFLG4033QT0 unit was beeping at our cabin this weekend. Couldn’t figure it out. Without any predictable pattern 1 beep or a few beeps. Its manufacture date is 2/16. We haven’t used it more than 20 times.
tarafından
I have the exact same problem with the same combo washer / dryer. Did you determine the cause / correction?
Thanks
tarafından
Mine does the same. Random 3 beeps several times a day every day.
tarafından
Hello! Mine is doing this now. Any updates on what it was?
tarafından
My Frigidaire stackable washer / dryer does the 3 quick beeps, but it also will not unlock the washing machine lid and I have to keep turning the cycle selector and turning the electrical breaker off then back on... and it's anyone's guess when it will unlock.
Sometimes I get so frustrated that I walk away and I hear the washer lid unlock maybe 30 to 60 minutes later all on it's own.
Can anyone tell me why all this is happening? I've already paid an appliance repair man $300.00 dollars, he changed the water inlet valve which I don't think was the problem at all... because it's still doing the same thing I called him out to fix.
By the way the name of the appliance repair company I used was Rogue Appliance Repair outside the New Orleans area... NEVER, NEVER call this company. They will not come back to figure out what is wrong with my washing machine... unless I pay them for another service call. Great repair warranty... right?
tarafından
1 tane daha yorum göster
Yorum Ekle
7 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Does this occur when the washer is in use?
Don’t know the answer but according to the owner manual:
Push in or turn the cycle selector knob or turn any option knob to "wake" the washer. You will hear three short beeps to indicate washer is ready to operate. After making your selections, push in the selector knob to start the cycle. You will hear one short beep and the washer lid will lock.
Perhaps if you hear the beeps when the washer is not in use, the cycle selector switch has to be either pulled out or in the home position. It may be just a reminder that it is ready to go otherwise.
Alternatively it may be if it is truly random and not in a time pattern that then there may be intermittent interruptions to the power supply to the unit.
Depending on your location there is either a single 240V power feed or a 2 x 120V power feed. If it is a 240V power feed you may be able to try connecting to another power outlet which uses a different fuse. If it is a 2 x 120V supply then unfortunately you cannot try this as the power outlet that the washer is connected to is specifically wired for the washer i.e. 2 fuses for the washer in the power box of the premises
Disconnect the washer’s power cord from the wall outlet if it is really annoying and only plug in when wanting to use it. That should stop the beeps. This will also reduce your power bill (not much but over 12 months it can add up. ;-), as a lot of appliances still draw a small amount of power when stopped but not turned off at the outlet i.e. standby power. I think that your unit will use power when not in use given that it can be turned on by “turning any option knob” to “wake” the unit as described in the manual. Option knobs usually aren’t power on/off switches.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I have tried resetting the power by turning off both breakers. The washer & dryer.
It beeps when not in use.
It does so randomly
There is nothing in the online manual or in the Electrolux/Frigidaire site that states what it is for or why it would do this.
Just annoying really
tarafından
@Stewart Fleming
The manual does state that if the washer is off, that it will beep three times when the you select a wash cycle OR operate an option switch, before you press the cycle switch in to start the wash.
That's why I suggested maybe it's a power flick from the mains power supply that is the problem as the combo unit is in a standby state rather than turned off i.e. the power is on then off momentarily then on again, so the washer thinks that it's being turned on - power is reconnected - but won't start because the cycle switch is not pushed in.
Try just turning off the one breaker to the dryer and then if it still happens restore the dryer breaker and turn off the breaker to the washer if it still occurs and see (or rather listen). By rights it shouldn't occur when the washer is isolated but not the dryer.
tarafından
Yorum Ekle
There are two different three-beep signals. Neither is mentioned in the accompanying “Use & Care” manual, but the usual three-beep signal is mentioned on the accompanying “Laundry Center Operating Instructions” separate sheet of paper as indicating that the washer or dryer has been powered-up from a “sleeping”, or low-power state. That three-beep signal is three shorter/quicker beeps. The other three-beep signal consists of three longer beeps, and indicates a problem. In my case, the problem is that I can eventually get the machine to wash and rinse (after a long period of the pump chug-chug-chugging followed by a silent delay and another round of pumping), but the drum will not spin at the end of the wash or rinse cycles, so the clothes are left very wet, and not fully rinsed.
Puan 2
4 Yorum:
Hi
What is the model number of the washer?
Knowing this may help to find the tech sheet which shows how the diagnostics can be run to see if they show the reason for it not spinning.
tarafından
Hi Frank
Have you found the issue off a three (3) long beep. The washer is not finishing its cycle and stay loaded with water. After a couple cycle stop/start, The unit finish its cycle but not often.
tarafından
@alexandred58024
If you have a FFLE3911QW0 then try running the diagnostic tests and check what error codes are being displayed.
tarafından
Hi frank I have the same problem, are fix this problem already? If so please can you share how you fixed please?
Thanks
tarafından
Yorum Ekle
The solution is replacing the washer/dryer cycle selector. When one of them starts going bad it will make a beeping noise without user input. Usually you can figure out which one is going bad because certain cycles will work normally and others won’t finish and can stop at different stages during the cycle. The other easy method I found to figure out which one is the culprit is to listen to the beep that the washer/dryer is making and then physically turn the knob your self without starting a cycle and see if the sound matches. The washer and dryer both make slightly different beeps when a cycle is being selected.
Puan 1
1 Yorum:
Changed selector from rinse spin to normal seems to be working also 3 beeps stopped I'll give you this one maybe selector going bad model 417.61712510 thank you
tarafından
Yorum Ekle
Same problem. Mine usually will not run a full normal cycle. It works for a while, then beeps, then stops. Sometimes it says I need to clean the filter (even when it is clean).
The solution I have found is to to switch to a timed dry (30 minutes) and repeat until the clothes are dry.
I’ve never had a problem with a dryer before…but this is my first ventless dryer. Maybe that’s a factor?
Puan 0
Yorum Ekle
My dryer beeps 3 short beeps at random times ALL NIGHT LONG !! it’s a stackable . Chime switch if OFF
W & D about 5 yrs .
Model FFLE2022MW2
HELP
Puan 0
2 Yorum:
Hi
I’m almost positive it’s my dryer that beeps ! How would I know if it was the washer ! Beeps occur when they are both not on and empty all through night . 3 fast beeps . Thanks
tarafından
Mine beeps when the lent filter isn't clean. If I leave clothes in the dryer, then I hear beeps in the middle of the night. My habit has always been to clean lent filter before each use, but I'm trying to remember to clean as soon as dryer finishes. My stackable is not new, but came with our condo. It works great other than the intermittent beeping.
tarafından
Yorum Ekle
I had this issue until I realized that one of the knobs (the temperature knob that says “high, medium, low”) on my stackable dryer was in between two of the settings. The beep was the dryers way of letting me know! Try checking all of your knobs and make sure they are turned to one setting or another, not in between settings. Hope this helps!
Puan 0
1 Yorum:
Thanks will check that out with the cycle knobs !! Happy Thanksgiving 🦃
tarafından
Yorum Ekle
My frigidaire washer was beeping randomly at times and other times didn’t. Sometimes would run spin cycle, sometimes didn’t. Until the day the spin cycle refused to start. I had to change the “Washer Door Lock Latch Switch Assembly”. It’s real easy to do, Just remove boot ring and pull boot out near latch. All you need then is a Phillips #2 screw driver. Remove the 2 screws holding the door latch, unplug it and plug in new one.(3plugs) There’s a video about it on YouTube.
Puan 0
Yorum Ekle
Yanıtını ekle
Stewart Fleming sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 130
Son 30 gün: 697
Her zaman: 34,392
