How to Replace CMOS CABLE Hard Driver cable Connector DD0BKETH000
I’m sure it will be evident once I receive the replacement cable, but where does it connect inside the touch display? thanks, David
Update (10/21/2020)
I understand and agree with almost everything you said except (and in the tutorial you referenced you can see in figure 8 the 2 wires coming from the connector) the cable I mentioned and that’s exactly what it’s called. Here is a link to where I’m purchasing mine with pictures: https://www.ebay.com/itm/DD0BKETH000-GEN...
The additional wire that is not going to the connector of the hard drive goes up with the wifi antenna cable and take a right there and to the hinge and I believe into the display. Whereever the second wire goes even if not to the display is what I’m trying to find out
I was surprised by the quick reply, but please take a moment to look at that cable and maybe from there you can help me out.
thanks
Bu iyi bir soru mu?
