Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Soru Tümünü görüntüle
Faded corners in the display of MacBook Pro Mid 2012 13 inch
Hi Guys,
Hope you are all doing safe!
Jumping on to the top straight away, I am having a white border fade issue in my macbook pro mid 2012 13” inch.
This fade is surely due to hardware issue (not sure if the display is the issue or something else).
The edges of the display is faded while the 4 corners have the maximum faded area as shown below:
Is it worth to get a display replaced for the model? Or Can I use it as it is?
I am happy to use it in the current way, but little skeptical if this fade would keep on increasing day by day :(.
Do you guys have experienced this issue earlier?
Please put in you suggestions and thoughts here.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Avinash™ Kumar what you have here is a failing display. Yes it could “f this fade would keep on increasing day by day” but it can always buy you some time before you have to replace it. In the meantime I would suggest use it until you feel it is time to either replacing it and/or keep it connected to an external display.
MacBook Pro 13" Unibody Mid 2012 Display Replacement
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Avinash™ Kumar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 419
