Where can I buy replacement screen
who sells replacement parts?
Bu iyi bir soru mu?
Hi @cyberrescuers,
Here’s the maintenance and service guide for the laptop.
Go to p.13 Item #4 or p.14 Item #1 to find the part numbers for the LCD panel for the non touchscreen and the touchscreen model variants for the PC.
If you search online using only the part number appropriate to your particular model variant you will get results for suppliers.
The manual also details the necessary pre-requisite steps and then the procedure to remove / replace the panel.
Hopefully this is of some help
Bu yanıt yardımcı oldu mu?
The issue with these Stream devices is cost :-(. Parts cost as much as a used one, or about as much as a new one on some of these.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 75
2 Yorum
Hi @cyberrescuers ,
What is the full model number of the laptop?
jayeff tarafından
@jayeff I have a stream 13
klarenceray tarafından
