Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
Touch id and home button cause iPhone 7 in apple logo loop
Some days ago i clean the front and back body of iphone 7 with a wet cloth after some days it’s home button and touch id not work properly it works sometimes and sometimes it didn’t .when i restart the phone ,it stuck on apple logo loop.then i open to repair phone and i plug out the home button strip and plug in again ,it turn on without any problem and work good when i assemble and restart ,it again stuck on apple logo then i plug out the home button strip and iphone starts working good without home button. Now what should i do now ?should i replace it or can i fix it .
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Take out carefully the home button and clean it with high percentage alcohol, I think when you have cleaned it it will no longer start in a loop.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
What should i clean ? The strip or touch id?
tarafından
Clean the front and back side of the home button and flex connector. Use a soft toothbrush and some alcohol, wait until everything is dry before putting it back.
tarafından
Yorum Ekle
Yanıtını ekle
John wick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 45
