Ana içeriğe geç
Samsung Galaxy A71, Samsung Electronics tarafından Galaxy A serisinin bir parçası olarak üretilen bir Android akıllı telefondur. Ocak 2020'de piyasaya sürülmüştür. Versiyonlar: SM-A715F/DS, SM-A715F/DSN (Global), SM-A715F/DSM (Rusya).
Water damage ghosting touch screen
Hi I accidentally dropped my Samsung a71 in water from my ear height it was only in it for a split second. I put it in rice for a few hours and then it worked but a few hours later the left hand side of screen stopped working and now the screen is ghosting could I ask if replacing screen is enough i opened up phone and can't see any water damage apart from red water indication
Bu iyi bir soru mu?
Puan 1
2 Yorum
So I dropped my Samsung Galaxya71 uw 5g in the water at the time all I did was try to dry it off didn't have anything really to put it in and you really can't take the back off to take the battery out so I let it set for a couple days it turns on and everything I have to touch screen just doesn't work so I can't like put my password in or it doesn't register any thing I'm catching on the screen I've tried to reboot it things how it's locked how do I what do I do
tarafından Paylaş
@Jordan Micheal
See the answer below.
The phone will have to be opened, either by you or a professional repairer.
It isn't going to fix itself. If anything the problems may get worse the longer that you leave it.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @spiderjocky11 ,
The liquid contact indicators turning red means that water has entered the phone.
It may be that the screen will have to be replaced but you will know this better once you are satisfied that it has been cleaned properly first.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
Rice does not fix the problems caused by corrosion Rice is for dinner, not repair
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in there also. The ends of any flex cables and their connectors need to be cleaned as well.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a teardown video that may help
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
I took it apart and can't see any damage at all. Also it was working for a few hours after I left it in rice and then after that I started using it and then the left hand side of touch didn't work and then it started ghosting touching on its own
tarafından Paylaş
@spiderjocky11
My answer still stands.
You couldn't see any damage but that doesn't mean that the damage hadn't already occurred and that it is just not visible.
Electronic components can fail if the water has provided a path for the current which wasn't supposed to be there normally.
At best what you can do now then is to replace the screen and check.
tarafından Paylaş
Ok thanks. I ordered some isopropyl alcohol. Does the a71 still have the issue with the fingerprint not registering when screen replacement
Show quoted text
tarafından Paylaş
@spiderjocky11
I don't know.
As far as I still know it is Android 10 checking the screen and fingerprint sensor serial numbers to see that they're OEM so unless you roll back to Android 9 somehow (the check is not done in Android 9) and prevent future updates then it seems only Samsung can fix the problem
tarafından Paylaş
Screen pink line isusse
tarafından Paylaş
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
JSP sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 38
Her zaman: 3,888
