Ana içeriğe geç
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Soru Tümünü görüntüle
Replace hard drive or buy new?
I have a 2017 27 inch iMac and the hard drive needs to be replaced. The repair shop said they could upgrade to an SSD drive for $500 total. The trade in value is $1100. Would you upgrade or just trade in and buy a new one?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
What is the size of your current drive and is it a Fusion Drive setup?
What are you looking for space the same or more?
tarafından
Hi Dan,
This was the configuration that I got:
4.0GHz quad-core Intel Core i7, Turbo Boost up to 4.2GHz
• 8GB 1867MHz DDR3 SDRAM - two 4GB —I upgraded it myself to 32 GB
• 3TB Fusion Drive
• AMD Radeon R9 M395X with 4GB video memory
The repair shop wants to replace the 3TB HD with a 1TB SSD. I don’t know if it’s worth it to spend around 400-500 for repairs or to trade in my computer at Apple for $1100 credit so I can buy the new iMac. What do you think?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
You know you can do this your self if you follow directions to the letter for a lot less!
So here’s the needed part, tools and sundries iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit $260 USD for a 1TB drive. And here’s the guide iMac 27" 2017 Hard Drive Replacement
The hardest part is pulling the display off. Many people use the wrong tools and/or force things. If you follow the guide to the letter you’ll be fine!
I would not do anything with the PCIe blade SSD which is the cache drive to your HDD when you had a Fusion Drive set. Wipe it down and just use it to hold loose files.
iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit Görseli
Ürün
$100.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
that configuration is still very usable. A 1TB SSD will make it seem like a new comouter. They do not cost that much if you install it yourself. About $100. They are not hard to replace as it is all plug-able. But then I am not a MAC person. IMHO, 400-500 is to much to pay.
Puan 0
Yorum Ekle
Don't bother opening up the machine. I would say run an external SSD. Boot up will be almost as fast, cheap fix, no hassles!
Puan 0
2 Yorum:
Why would you want to be hassled with three items (laptop, drive, and cable) to carry around, connect/disconnect, and subject to damage?
tarafından
@ruggb not sure if you want carry around 27" iMac ;)
tarafından
Yorum Ekle
Yanıtını ekle
Kat Kaye sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 104
Her zaman: 3,739
