Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 Soru Tümünü görüntüle
Graphics card not showing up causing no backlight
Hello,
a little while ago my Earl 2013 MBP the back light stopped working upon investigation I believe it’s a 1.5GB Nvidia 660m doesn’t show up at all in the system there is no kernal panics the only issue is the backlight it’s temperamental
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
This series came in two configs with and without a discreet GPU, AMD GPU (DG) vs intergraded Intel graphics engine only (IG)
IG Models: MacBookPro11,2
DG Models: MacBookPro11,3
So lets not get lost on the different graphics this series offers as that doesn't involve the backlight.
tarafından
Thank you Dan for getting back to me I will check it in a moment
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Most likely you have some corrosion damage either on the logic board display connector
Or within the displays connection (very difficult to get to)
Follow this guide to at least checkout your logic board connection MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement Follow Steps 1 through 4 to disconnect the battery, then jump down to Step 11. How does the contacts and solder joints look? Post some clear pics if you’ve not sure Adding images to an existing question.
MacBook Pro 15" Retina Display Early 2013 Display Assembly Görseli
Kılavuz
Zorluk:
Zor
1 - 2 hours
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Hey Dan I have done extensive checking for corrosion and there is none as for the other connector it’s all secure and no problems there
tarafından
@peach production - Plug in an external monitor with either the HDMI or Thunderbolt ports. Is that display working without a problem?
tarafından
Yorum Ekle
Yanıtını ekle
peach production sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 89
