Ana içeriğe geç
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Soru Tümünü görüntüle
Rubber plugs in replacement MacBook battery cause installation problem
I replaced the battery in my Macbook Pro 13” Retina Display Late 2013 (whew) with no issues. A question though:
The battery is built on a plastic frame with four mounting holes which match threaded holes in the computers baseplate, but there are no screws holding the battery in place - double stick tape does that job (a design change I guess). The four holes in the battery’s frame are filled with rubber plugs, which appear to do nothing but hide the holes (can’t say I blame Apple for this, without plugs it would look like they forgot to install screws). OK, that’s fine.
The new battery also has the mounting holes plugged, but these plugs are different - they have a “tail” that protrudes through the hole, interfering with the battery’s fit to the baseplate. The old battery’s plugs had no protruding tail, they appeared to be heat-staked flat on the bottom. I had to remove the plugs from the new battery, else it would have refused to fit flush, preventing the adhesive from doing its job and possibly preventing the case from closing.
Why are the plugs included when they interfere with the installation and have to be removed? The instruction made no mention of this. Am I misunderstanding something?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Take pictures, it’s kind hard to understand with text.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I had this same thing and ended up cutting the ‘legs’ off so that the ‘cap’ of the plug is still there. I took a photo to show the problem (and messed about with the contrast etc so it’s clearer).
From the photo looks like it’s a “You’re doing it wrong” scenario but the plugs are about twice the width of the holes they cover so can’t even be squashed in.
Puan 1
1 Yorum:
Ah! The molding fill tube was not cut off! Just use some cutters to fut it flush to the top of the dome.
tarafından
Yorum Ekle
Here’s an image of the battery to help you
Can you point out what you are seeing different.
Puan 0
Yorum Ekle
Yanıtını ekle
Christopher Raymond sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 116
