Ana içeriğe geç
The Honda General Purpose Motor model GX160UT2 is an air-cooled, four-stroke, overhead-valve, 163 cc, 4.8 HP (3.6 kW) engine. Supporting sub-models QWX2, QX2, RH2, TX2.
Pull cord mot starting
Pull cord will not pull. Flywheel works perfectly, when i pull the cord, and then align it back , it does not retract. The flywheel rotor has limited movement
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Broken spool spring - common failure. If you're not familiar with recoil spool repair, take it to someone who is. You could try YouTube, but mistakes with highly spring tensioned objects get ugly Fast.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Definitely the spool spring. This can happen just by use, weather conditions, or by impacts on that side. Be careful when repairing the spring, like Kevin says it can get ugly fast. I have gotten hit in the face by one before.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Trent sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 134
