Ana içeriğe geç
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
39 Soru Tümünü görüntüle
My Bose Wave Radio makes distorted humming when plugged in
This question was asked already but maybe I have more luck than the previous person. When I plug in the Wave Radio it makes a distored noise. I assume there is a electrical issue. Is it possible to save it from the trash?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
@rahhh can you post an audio file so we can hear what it sounds like? You will most likely have to take it apart, so post some good pictures of your circuit boards etc. That way we can see what you see.
Adding images to an existing question
Failed electrolytic capacitors are a possibility but one cannot rule out bad audio IC's on the amplifier circuitry.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Can you open the radio and check for any leaky or bulged capacitors? I have attached a picture below for reference.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
r z sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 668
