Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Ok to keep lithium battery plugged in charger?
So I just replaced my old swollen battery in my laptop with this new battery: MacBook Pro 15" Retina (Mid 2015) Battery
Is it good for the new battery if I keep the laptop plugged in its charger all the time? I.e. use the laptop as a desktop? TIA.
Replace a 8800 mAh battery compatible with a MacBook Pro 15" Retina (Mid 2015). 99 Watt Hours (Wh), 11.26 Volts (V.) Görseli
Ürün
$109.99
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This usage should be fine. I would, however, recommend plugging out the laptop and using the battery until the percentage indicator gets to 30% about once a month. After the battery gets to 30%, you can plug the laptop back in.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Mary sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 23
