Ana içeriğe geç
Google'ın yenilenmiş Pixel Buds'ı için onarım bilgileri—Nisan 2020'de piyasaya sürülen tam kablosuz kulaklıklar. Bazen Pixel Buds 2 veya Pixel Buds 2020 olarak da adlandırılır.
Can you replace the battery?
The pixel buds disconnect whenever they are removed from the case. I think the batteries are bad. Is it possible to replace the battery?
Bu iyi bir soru mu?
Puan 2
1 Yorum
I'm not seeing replacement batteries for the buds themselves, and the process looks pretty destructive. These aren't made to come apart.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Here’s the Ifixit Google Pixel Buds 2 Teardown guide which shows how to open the ear buds.
The guide was only to show the internal components and is not intended as a repair guide because of the damaging way in which the earbuds have to be opened.
The battery is a Varta CP1240 A3 (supplier example only) if you think that you want to try and replace them
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
If anyone is attempting this repair, I had good results with using a pair of pliers and gently applying enough pressure to bend the plastic slightly to crack the seal with minimal damage to anything else
tarafından
Yorum Ekle
En Yararlı Yanıt
I don't believe it is possible to open these earbuds without damaging the casing. Therefore, you cannot replace the battery.
Puan 3
Yorum Ekle
Yanıtını ekle
Joshua Stouffer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 78
Her zaman: 9,778
