Ana içeriğe geç
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
84 Soru Tümünü görüntüle
waking it up from sleep the monitor did flicker
Hey folks!
It's almost 2022 and this monitor is till knocking around. I really is a nice display and design and would hate to throw it out. I tried Barkin Tunga's fix and tough it didn't solve the problem it did confirm that the monitor still has life in it.
Barkin Tunga's fix here: 24" LED Cinema Display flickers then dies (A1267)
Upon waking it up from sleep (connected to a 2013 MBP) the monitor did flicker and I could clearly see the desktop wallpaper on the display.
It seems to seems to me either something is loose, (cable?) or it could be a cold solder joint. Suggestions are welcome as to the real culprit.
Thanks folks!
~ EMJWAYLZ
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
To figure out the fault, you will need to disassemble the display until you can get access to the circuit boards in the machine. The videos Apple Cinema Display - Teardown and Repair and How To fix An Apple Cinema Display should help.
Take pictures of both sides of the circuit board and upload them here Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Good answer +
tarafından
Yorum Ekle
Yanıtını ekle
Michael J. Walls sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 49
