Spacebar cracked, how do I replace?
Was trying to remove the spacebar to clean and it cracked. Where do I get a new one and how do I replace it properly?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Hi ,
You may be able to fix it yourself.
Here’s a link that will help with this. Select your key and key type
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 272
4 Yorum
Is this an internal laptop keyboard or a separate desktop keyboard?
Ken Grubb tarafından
William Waite your computer is a Dell Alienware 15 R3?
oldturkey03 tarafından
Duh, I see it now. Have you reached out to Dell to see how much a replacement keyboard is? That helps in computing a repair. It should also get you to install instructions to help you removing the keyboard to look at whether and how you can repair it.
Internal keyboard. Yes, Alienware m15 r3 I believe. I have not contacted Dell. Taking it to a repair shop tomorrow for analysis and estimate.
William Waite tarafından
