Why my screen has lines and is distorted at times, also blinks a lot?
my screen has some lines and some times the images are distorted, also blinks a lot.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Jose Zavala let's see what this all looks like. Post some images of what your screen shows you, with your question. Edit your QUESTION and use this guide Adding images to an existing question
To make sure it is your LCD that may have issues, connect an external monitor to your Surface. You will need a DP (DisplayPort) connector to get this accomplished. If that monitorshows a clear picture, (without the lines etc.) you know that the problem is your LCD dispaly. If an external monitor displays the same issues as your LCD, you know that this problem is caused by your GPU etc. which will compliocate the repair.
Bu yanıt yardımcı oldu mu?
I would recommended a screen replacement.
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 124
