Is there anyway to unbrick a WiiU?
WiiU is stuck on WiiU logo. Is there anyway to fix this. Like a chip or new HHD or something?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
When a Wii U is stuck on the White Screen with the Wii U logo, there are a few ways to try to fix it.
The first is to move your Wii U Gamepad reaaaaaally far away from the console, and then power it on when you are sure it wont be able to connect, and see if it starts.
The second is to power off the Wii U and bring your Wii U Gamepad back into range, so you can use your Wii U GamePad, Wii Remote, or Wii U Pro Controller, to power on the Wii U again.
Press/Hold B when the White Screen with the Wii U logo shows up, it may load into vWii mode, and from there you can exit to the Wii U Menu.
The final option is the most difficult, make a hardware dump of the current state of your eMMC user data, and Wii U NAND.
And try to manually repair the dumps on a PC.
Here are some images from WiiUBrew, good luck!
eMMC:
NAND:
Bu yanıt yardımcı oldu mu?
This just happened to me 12/27/22. My unmodded WiiU had an update, and froze at 90% complete. I force shut it off, and "bricked" my console. Only WiiU logo popped up, and nothing else. Wound up buying a switch because i thought i was screwed. (Have over 100 hours of Zelda: BOTW in the WiiU) BUT...I tried something, and IT WORKED, at least for my situation.
***Turn on console while holding down the A B X Y buttons. (Hold all 4 buttons down at the same time). Keep all buttons held down until something changes. Eventually, the screen changed to a message prompt, then allowed me to sign in like nothing ever happened. It works good as new, and my save files are all intact. It sounds too easy, but I swear that is all I did. Hope this helps somebody out there.
P.s. i unscrewed the battery on the actual console, and put it back in before I tried this. (Its the only screw visible on the console) I don't know if this had anything to do with it, but I figured I'd say everything I did.
I just fixed my Wii U by doing this thank you so much my only question is how and why does this work, I didn’t even need to take out the battery.
Bananaman1969 please tell be how you did it.
@bananaman1969 like what did it look like, how much time did you hold on the startup, when did you press all the buttons. it is not working 4 me.
Son 24 Saat: 38
Son 7 gün: 218
Son 30 gün: 954
Her zaman: 3,458
6 Comments
What is an HHD?
Andrew S tarafından
The hard drive
Daniel Asaad tarafından
@thunderbye There is no hard drive in a Wii U
Andrew S tarafından
Do you have a gamepad connected to the Wii U?
Andrew S tarafından
There is a hat drive, and I don’t have anything connected unfortunately….@andrewsawesome
1 tane daha yorum göster
