Ana içeriğe geç
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
Probably Dead From Water?
So, somehow my 3DS got mixed in with my dirty clothes and I don’t really put my clothes in the washer one by one. I just sorta dump them all in. So, my DS went through a nearly 50min wash cycle. Is there any way I could salvage it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Skye Tor probably not but you can always try. For now you want to stop using it, charging it or trying anything else.
Disassemble your 3DSXL using these guides . You must remove all EMI shields from your motherboard. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a Apple iPhone all the points are still pertinent to your device. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, you must replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your game and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a least a bad LCD and replacing the display assemblies may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
If unsure of anything, you can always post some images of what you encounter with your QUESTION. That way we can see what you see. Adding images to an existing question
iPhone Görseli
Kılavuz
Repairing iPhone Liquid Damage
Zorluk:
Zor
1 - 2 hours
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Skye Toren sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 128
